Results 1 to 10 of 11
Thread: Rear Wheel Bearing - Not Vec, but a Clio
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Rear Wheel Bearing - Not Vec, but a Clio
    Hi All,
    I know its not a Vec - but seeing as your all knowledgable chaps - thought I would ask in the place that someone would know
    Mate of mine's missus has a 2002 1.2 16v Renalt Clio and the rear off side wheel bearing has gone, so has asked me to replace.
    Its a Drum style brake setup on the back..
    So - is this going to be relativley easy - will I need any special tools, and has anyone done this before on the clio.
    Any help really appreciated..
    Thanks Anthony
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    the hub nut is tightened to 175nm so will be fairly tight,but from past experience of french cars the hub nut will be a staked type so you will need a new nut
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by solorider View Post
    So - once I have undone that - I take it I then just take old bearing out and put new in?? Simple?
    A
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    these are easy and should take about 30 mins, once you have removed the wheel and the hub nut, release the hand break so it releases the drum then it should just pull forward, once it off there is a circlip in the outter side of the drum remove it and then turn the drum over and with a hammer and chisel/punch knock the bearing all the way out, once its out get the new one and tap it in till it stops and then replace everything as you took it off. HTH
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    in most cases there are only 2 types of rear wheel bearing on a front wheel drive car,a sealed type like what is fitted to the vauxhall range or a seperate bearing which are tapped out and back in,you will know more once you have the bearing but as you have a hub nut the latter type would be favourite
    most off the old vx have tappered rear bearings in drums and some on discs, the new vx have solid bearings like you get on the front, the clio will bear a solid bearing so its just a knock out and in
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by glynn View Post
    Great mate - fantastic help both of you thanks very much.
    So the bearing sits in the removable drum and not in the hub itself?
    A
    Quote Originally Posted by AntSSSS View Post
    A
    the hub is part off the drum and yes to the question, hope you get it sorted out
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK - seems no problem then.
    My definitiion of 'Drum' is the casing that the rear shoes press on to stop - I am right arnt I - lol?
    A
    A
    yes m8 that correct.......LOL
  1. rear wheel bearing
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2011, 19:19
  2. Rear wheel bearing/hub help
    By daviem-rfc in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 23:38
  3. rear wheel bearing??
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 22:14
  4. Rear wheel bearing
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2006, 16:23
