Thread: Rear brake caliper
    Regular Member NI-2.2SRI's Avatar
    Northern Ireland
    Default Rear brake caliper
    Was wondering did anyone hav any idea / info on removing the handbrake cable from the rear caliper?? any help would be great
    (part is circled in the pic below)
    cheers G
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    thats knackered mate
    chap the circled bit out from the bottom of your pic and replace with a new cable
    May 2008
    Tyneside
    Looks like you need a new handbrake cable. Mine was very tight and just sits in a recess in the lever. Smother it in WD40 and get some grips on the cable (biggest diameter section) and try to rotate it, it will eventually fall out.
    Northern Ireland
    cheers for the replys, the capiler pictured is a second hand one, the cable u see is jus a bit thats stuck in the calipher, my cables ok.
    my capliher seized, wore the pads out in bout 5 weeks!!!!! lol
  1. Rear brake caliper problem
    By siadwel in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2012, 16:37
  2. Rear brake Caliper
    By scoles1 in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 23:16
  3. rear brake caliper
    By jerc in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2007, 13:56
