Thread: tracking check needed?
    durham
    Trim : Leather
    Default tracking check needed?
    hi, just fitted eibach 30mm lowering springs which seen as its the sri its actually dropped it 15mm, now my tracking was spot on, so can i risk it and hope the tracking is ok, or will it deffinatly need doing? thanks.
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Quote Originally Posted by tonyblade View Post
    Dont risk it mate...its lower over standard now so will be out even if you dont notice it much
    Regular Member Ben999's Avatar
    Milton keynes
    i would say its a must, and the camber as well. Id rather pay however much they charge to check and adjust (£30-£40?) than risk needing two new set of tires in 6 months.
    durham
    Trim : Leather
    thanks guys so do i ask for a tracking check only, or a tracking and camber check?
    Just wheel alingment mate...its all digital now if you go to the right place you will be fine if the know what their doing
    durham
    Trim : Leather
    thanks dose will book it in to the dealer i trust . sherwoods at darlo. thanks.
    Jul 2006
    Just be warned - most dealers's can't do 4 wheel alignment, which is what you need. Make sure you're specific when you ask.
    durham
    Trim : Leather
    did not know that paul! thank you for that! ive found a place in gateshead that do the 4 wheel alignment on a hunter machine? if it needs adjusting its about £100! bit of a shock that but if it saves my tyres then will have to bite the bullet, thanks for your advice paul.
  1. Tracking/4 wheel alignment needed after new trak rod end/lowering 35mm
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2013, 23:13
  2. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  3. For Sale: RAC Car Data Check (similar to HPI Check) - £10.00
    Last Post: 29th July 2011, 08:49
  4. RAC Car Data Check (similar to HPI Check) - £10.00
    Last Post: 18th March 2011, 13:43
  5. fuse list needed to check windscreen washers
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 13:06
