Results 1 to 10 of 19
Thread: Tyre advice required!!!!
    Sunny Dartmoor
    Default Tyre advice required!!!!
    I noticed today that one of my front tyres is wearing on the inside edge,only had the tracking done last month due to tie rod worn for MOT,so searching for some different tyres.Currently have Khumo's on and want a better tyre,after 2 just for the front,have seen these and think they are a good price........
    What do you all think? Any suggestions required,i'm currently running 225/40/18............
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    thats if they did it correctly glen, them tyres seem to be a very good price m8
    Stockton on Tees
    I've always trusted Pirelli P Zero Nero's. Very good grip in the dry and one of the best in the wet too! I only had them in 17x205/45 and i got them for £60 fitted each!! This was last year as i don't have these wheels anymore
    Sunny Dartmoor
    the toyos would be better for milage, as the yokos work better when hot
    The inside edge tyre wear would be a result of the initial wear
    Without tracking this wear would have continued to a worse degree
    It is always best to perform tracking when the tyres on the front are new or swapped from the rear to the front
    I suggest you take the rear tyres and put them on the front, and put the new tyres on the rear
    At the same time get the tracking rechecked, the place that did this should do it free (most places only charge for adjustment)
    Finally, stay with the same tyres, no matter what you had put on they would have worn with that pattern!
    Sunny Dartmoor
    Don't really want to stay with the Khumo's to be honest,want to get some better tyres that will last a bit longer than 11k as these did........
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    humm my pirelly have sofar lastet 30.000 miles...
    Sunny Dartmoor
    Anyone else with some suggestions............
    11K miles isn't so bad if they have only ever been on the front
    You can get about 20K miles out of a tyre if you swap them rear to front as you wear out the fronts
    If you are looking for tyres that will last a long time, or are a high mileage driver, then consider Michelin Primacy HP
    These are slightly harder tyres and will last about 20% longer, but you will pay slightly more (but the cost per mile will be less)
    I am currently waiting for Good Year to come back with a suitable tyre for me to compare to the GSD3
  1. Advice required :)
    By Paul_NI in forum Detailing and Car Care Discussion
    Last Post: 13th June 2011, 14:01
  2. 3.2 SRI V6 advice required
    By chrisgg90 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 02:32
  3. Help Advice required
    By Graeme in forum Engine & Drivetrain
    Last Post: 4th December 2008, 00:35
  4. advice required ?
    By rob 2.2dti in forum Comedy & Humour
    Last Post: 3rd July 2007, 08:25
