Results 1 to 10 of 14
Thread: Heated seat pads...
    Northampton, UK
    Default Heated seat pads...
    Does anyone know if the Front Heated Seat Pads from a Vauxhall Astra Mk4/G would work in a on a Signum/Vectra?
    Part numbers I can see are -
    Backrest Pads - 90560060
    Base Pads - 90560059
    Northampton, UK
    Anyone?
    I've also been looking at these for the front and back.
    Regular Member zazaszazas's Avatar
    Cumbria
    Quote Originally Posted by n_hudson View Post
    Anyone?
    I've had that waeco kit fitted into my previous car.
    Northampton, UK
    Quote Originally Posted by zazaszazas View Post
    How did you find it? How does it work exactly? Where do you wire it to or from?
    Cumbria
    Well my previous car had factory fitted heated front seats so i just wired them into the front seat circulation...They worked fine(took a bit longer to heat them up than the factory ones tho')They have 2 settings low heat and high one.I dunno much about Vectra(just bought the car 8weeks ago)but what i can read in this forum u need tech2 almost for everything.To my old car(Ford) was very easy to fit...I am just wondering you can wire them into your cig lighter loom......
    Northampton, UK
    I've got all the loom under the seats and the plugs behind the blanks. So could I "maybe" just wire it to that? I've got the heated seat switches etc, I've just been trying to find some seat pads to complete it all! But if I could maybe use the VX switches and loom with these pads, that would be better and easier for me. Mines a pre-facelift so very little tech2 needed for her.
    Cumbria
    Well if u got all the loom installed to retrofit the heated seats can't see why it wouldn't work.Why don't u try to get some genuine Vx ones from Omega c(almost all of them had heated seats)would be easier to fit me think...
    Northampton, UK
    An Omega C, is that the final production facelift model, up to 2002 or something like that? It would work in on a Vec C/Sigbum?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes thats the last model.. modelyear 2000-2002. Some features there are shared with the prefacelift vectra
    edit: you could also choose the get the original for the Vec/signum
    Cumbria
    I think up to 2003...Can't see the reason why won't work...Any idea how much the pads would cost new from the stealers?
  1. Heated Seat Pads.
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 09:05
  2. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
how to test if seat pads are working on vectra C
vectra c heated seat pads
