Thread: Wheel wobble at speed, after changing to 314discs
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default Wheel wobble at speed, after changing to 314discs
    Hi
    Just thought id better ask...
    A little while ago, I upgraded the brakes to 314 (via the SAAB route), i accept these were used and a little unknown of origin, but since they have been on, at speed when the brake pedal is pressed you get massive wheel wobble, there is no wheel wobble at all until the brake is depressed.
    Do you guys feel its just a warped disc? or could it be the calipers?
    cheers...
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    warped discs m8
    Belfast
    Agreed, good chance the disc is warped.
    member of the smoke patrol 230bhp+
    its the disc's
    Full Member Big Sig's Avatar
    Or there is some dirt stuck behind the disk giving it the appearence of being warped. Whip them off and have a clean behind them just incase something got trapped in there before splashing out on new disks.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    What Big Sig said!! Clean the hub!! it takes just a minute but no one does it!
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    cheers guys... hard to believe that solid steel gets warped, ill try that first....
    they have done it since install....
    just in case, sorry to change the thread a little,,
    ... anyone got the PN for 314 discs???
    cheers lads
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    As said 99% chance warped discs mate...you could have the descs skimmed for much cheapness
    Quote Originally Posted by _ZS_ View Post
    In my experience the disc is usually the culprit HTH ......
    Jul 2006
    Quote Originally Posted by dv8 View Post
    Usually they don't actually warp, it's deposits of friction material from the pads that are left if they're not bedded in properly. But taking it apart and cleaning the hub with a wire brush is a good start.
    cheers lads
    Yep, in the part numbers section. £65+VAT for new discs and pads.
  1. Wheel Wobble - What next?
    By logi6260 in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2011, 16:13
  2. Wheel wobble
    By signumboy in forum Handling & Braking
    Last Post: 2nd November 2010, 16:25
  3. Wheel wobble at 40 to 50 mph
    By iwoo in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2009, 15:56
  4. 6 Speed Box Wobble?
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2007, 01:21
  5. Wheel wobble
    By raymie.d in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2007, 16:09
