Thread: Consequences of too much engine oil...
    Chelmsford
    Default Consequences of too much engine oil...
    My brother, who isn't the most car-minded person, recently bought a Fiat Cinquecento. He was driving it today when the temp warning light came on (it's too basic to actually have a proper guage!) so he topped up the coolant reservoir which was showing quite a low level.
    This had no effect so a few miles later he took a look at the oil level which appeared to be low, so he added some... Far too much sadly (about 3 litres too much...)
    Immediately he started getting white (possibly blue-greyish) smoke from the exhaust.
    I've told him to drain the oil completely and put in the correct amount, but I'm concerned about damage that he may have done.
    Anyone got any ideas for me? Is a short spell with too much oil going to cause any major problems?
    Cheers.
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    with the extra oil will come extra oil pressure which only really needs a few minutes before damage can start to happen most comonly is oil pump valves but anything can be damaged really even worn gaskets being broken.
    Chelmsford
    Hmm, I had a horrible feeling that would be the case...
    Any guesses as to what this smoke could be the result of?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Cylinder head gasket blown, allowing water to go where water should not go. You neeed to get a pressure test done, and get your oil checked for signs of water contamination.
    3.2 v6 Signum and loving it
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    seals/gaskets can pop, get a compresion test done
    Belfast
    Or it was blowing oil into the air intake through the breather. It may clear up once the correct amount of oil is put in the engine.
    Regular Member Stuarty's Avatar
    Aberdeenshire
    You may find its ok and its just the oil burning as theres obviously to much in it deffo get it drained and see how it behaves best of luck to him..
    Chelmsford
    Cheers for the help guys!
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. Replies: 35
    Last Post: 5th May 2012, 15:32
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
ive put too much oil in the car vectra 3.2 v6
