Thread: 2.2 Direct SRi
    Full Member spennny's Avatar
    Blantyre
    Default 2.2 Direct SRi
    Can anything be done to the engines to get some more BHP
    I have heard that you cant ....
    Wales, UK
    The Z22 xan be supercharged, courtney vx kit for around £3000 !! It does
    take it toaround 260bhp tho...
    Smooth the TB, 2.4 inlet canbe purchased, remove the Pre cat....
    Think this canbe done to the Vec B, will unleash a few extra Ponies !!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I think the stuff listed above is for the Z22SE engine.
    I believe there is a remap available for the Z22YH, IIRC an I500 owner on here had it done. HTH
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by mark_647 View Post
    Not for the YH mate. Yes the 2.2 can be supercharged but only on the SE and not in the Vec C unless you get a stand alone ECU and spent 1000's just to get round the canbus. Throttle bodies are also available, but again not on the Vec C.
    The YH manifold is of the variable flow type so again the 2.4 inlet is a no no i'm afraid as its only a direct replacement for the SE. Port and Polishing the inlet is however an option. The 2.4 TB will not run but the 2.0SC tb from the US can be made to work on the SE but never tried on the YH. TBH, your looking at a Cat back system, sports cat, Piper zorst manifold, custom down pipe, Landrover one fits and only really a good filter on the inlet side. Tie all this in with a Map and you might see 170 bhp+, but the map will really help drivability. Adding cams will see you nearer the 180 mark at a guess, but to the detriment of the drivability. HTH
    Full Member Penfold101's Avatar
    One of the many times it's probably cheaper to just go and buy a more powerful car...
    Oct 2006
    Wellingborough
    Curious whether a nitrous system would fallfoul of canbus. If not it may be a serious option for the YH.
    Vehicle : SRi
    Mileage : 137000
    Big P, love the new "location" time for a new Sig though.
    Quote Originally Posted by spennny View Post
    Why, do you want more? ..................... ................
    Apr 2006
    Cheers Rushy, gonna try and sort one shortly.
  1. I think my 2.2 direct has too much oil in it....
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 15:18
  2. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
  3. 2.2 Direct mpg normally this bad?
    By Marc C in forum Engine & Drivetrain
    Last Post: 9th August 2008, 12:46
  4. 2.2 Direct 16v
    By cdms811 in forum Petrol Engine related
    Last Post: 12th December 2007, 00:55
  5. 2.2 Direct
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 20:50
