Results 1 to 10 of 11
Thread: Intermittent Cruise Control Problem
    Regular Member Bobarache's Avatar
    Jan 2009
    Perth, Australia
    Default Intermittent Cruise Control Problem
    Every now and again I have a problem with my cruise control, if I disable it and then try to enable it again it won't switch back on.
    The only way to get it to enable is to switch off the ignition and turn it back on.
    My brother-inlaw has an 06 CDXI Vectra and he has had the same problem from time to time.
    Am wondering if this is a common fault in Vectra's, am interested if anyone else has the same intermittent problem.
    Mileage : 000
    Might be the spring on the clutch pedal.
    lanark
    6 Post(s)
    Year : 2017
    Quote Originally Posted by ed taylor View Post
    aye have you tried to put your foot under the clutch pedal and just give it a gentle little pull that usualy works
    Regular Member Phil MC's Avatar
    Oct 2008
    Kirkie
    The three things I've encountered during my ownership of three different Vectra C's are:
    1) Clutch pedal switch- give pedal a tap and then re-try to engage.
    2) Brake pedal switch - give pedal a tap and then re-try to engage.
    3) If there's an underlying defect that your ECU is picking up on then depending on the fault it can inhibit the Cruise Control engagement - try a fault code read to see if there is a code present and try to clear it.
    Good luck,
    Phil C
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Quote Originally Posted by Bobarache View Post
    Yep me to.
    If I hit the slow down button it goes off untill I restart the car.
    If I hit the Cancel button it goes off but I can re set it
    Tryed all the clutch and brake things with no luck!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Dirty stalk switch connections?? Contact spray and rapid switching to clean - worked for mine.
    Jan 2007
    Chelmsford
    I agree with ste, the buttons are a bit rubbish and get bunged up easily.
    I have a problem with mine sometimes. The cruise won't activate unless I press the button really hard.
    Jan 2009
    Perth, Australia
    Quote Originally Posted by andymagee1982 View Post
    Yep me to.
    Does that happen everytime or only now and again ?
    Cheers guys....I will give them all a try, it is a bit of a pain in the ass to fault find as it only happens now and again.
    May 2008
    Widnes.
    It does it all the time.
    No codes on mine
    Mar 2008
    slough
    hi people i have a problem with the cruise control on my 56 plate vectra c ,it intermitantly switches off i have replaced the control arm, the clutch switch the brake switch the throttle pedal complete and it still dose it, im tieing a noose at the moment so please for give me if i dont reply for some time. thanx guys. sad man............
  1. Intermittent cruise control & oil can light...HELP NEEDED
    By simmo3187 in forum Engine & Drivetrain
    Last Post: 12th July 2012, 14:06
  2. Another Cruise control Problem
    By Nezza42 in forum Engine & Drivetrain
    Last Post: 16th June 2012, 16:20
  3. sorry another cruise control problem
    By david.mann8 in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2012, 15:35
  4. Cruise control intermittent working, ( faulty CIM possible?)
    By jon1.9cdti in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 23:32
  5. Cruise control problem
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2007, 20:26
vectra c cruise control intermittent
https:www.vectra-c.comforumshowthread.php74377-Intermittent-Cruise-Control-Problempage2
my vectra cruise control disables
