Thread: indicator bulb on head light
    Feb 2007
    GREENOCK
    Default indicator bulb on head light
    How do you change the bulb on the indicator light on my facelit headlight..thanks
    With great difficulty!
    Its bad enough in the prefacelift
    Which side is it?
    For the nearside, unclip the windscreen washer reservoir and you have limited access
    For the offside, you have no access
    The usual solution is to to unscrew the two lower bumper valence screws, pull the bumper free from its housing and access from there!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If its the driver side, can you not remove the lid off of the Airbox?
    Gazza4
    You need to remove the entire air box
    Never tried it myself, but apparently it can be done with one great pull!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I was gonna do that but terrified of ripping the the Looms that Vx decided to attach to it
    Gazza4
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    easiest way is to remove bumper
    then remove the headlight
    sounds bad i know but is easier than leaving your knuckle skin on the inside of your car
    Feb 2007
    GREENOCK
    does anybody have ant pictures how to do this..i have tried to turn the connection were the bulb is but it wont move..am i turning the correct thing?
  1. Replacing head light bulb
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2012, 11:32
  2. Changing head light bulb Dip beam
    By hamish123 in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2011, 12:08
  3. ****** light out bulb warning and indicator
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2010, 02:08
  4. renewed o/s/f dipped head light bulb
    By cranny 27 in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2010, 22:36
  5. Head light bulb types.
    By Jekyll & Hyde in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 19:27
