Results 1 to 10 of 24
Thread: Airbag light
    Regular Member texaspete1973's Avatar
    cardiff
    Default Airbag light
    MY AIRBAG LIGHT CAME ON TODAY AND STAYED ON,ANY IDEAS ON WHAT IT COULD BE. I DONT HAVE A FAULT CODE READER SO I WAS WONDERING IF THERE ARE ANY COMMON FAULTS WITH THE SYSTEM THAT I COULD CHECK
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    Check the connections under the seats.. If the seat is moved regulary they can work loose..
    cardiff
    I will check now, thanks
    cardiff
    Still on
    cardiff
    Default air bag light
    Many thanks to dr.direct,after closer inspection in the daylight it was one of the connections under the seat.one of my kids had moved the mat with her feet which then pushed the connection slightly apart.
    Widnes, Cheshire
    Good result!!
    I have the nasty airbag light
    I was cleaning the car yesterday and must have knocked one of the conectors under the seat, ive cleaned the contacts & re conected, the airbag light still on as apparently it needs a reset???? Dealers asking for £45 + VAT!!!
    i assume disconected the battery will not work, would the RAC code readers be able to reset the light??
    Regular Member Craig1985's Avatar
    harwich essex
    will need tec2 or simular to reset once the connection has been interupted.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Are you sure about the Tec 2 reset after the fault has been removed?
    harwich essex
    i am 110% surre. Had same fault on my vec b and C both had to be reset
  1. Airbag light!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 01:52
  2. Airbag light
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:26
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  5. Airbag Light
    By Hollingsworth87 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2011, 16:29
