Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Odd ticking noise
    confused Odd ticking noise
    So after having my aux belt replaced I now have noticed a new noise. I am 99% sure it was there before too but thought it was the aux belt, I am now not so sure.
    Its only audiable at tick over speed, it goes as soon as the rev's climb - even a little. If reved and allowed to drop to idle of its own accord a different sort of "swooshing" noise can be noticed until the revs are at idle and then the ticking starts again.
    The tapping could be the hyd tappets I guess but it only seems to be at one end of the engine - can just notice it over the diesel clatter! Its there at any engine temperature. It all seems to be at the cambelt end of the engine too if that helps.
    Its a 2003 3.0cdti with 67k on the clock
    Regular Member simac's Avatar
    Wirral
    It sounds very similar to a sound I had which turned out to be the water pump which is driven by the aux belt (on the 1.8 anyway). could be a good place to start.
    thanks for that but i believe the water pump is not belt driven on the v6 diesel
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    My old 2.0 ECOTEC Cav broke an exhaust manifold stud at the belt end.
    I was convinced I had a tappet going, until I spotted it.
    Similar tapping at idle, but inaudable as revs rose - worth a thought ?
    think i'm going to have to poke about on monday!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    myn has it too sounds like a loose bolt ... its had it from day one and beeing as ive looked after her from new then when i got her i wasnt too worried about it i cant be arsed to find it now ill waite for some thing to drop off ...
    Mileage : 000
    They were good at doing that. I have had to replace both top and bottom Exhaust studs on the wifes Vectra B. Bit of a pig to do when in situ. But I did manage to drill both of the broken studs out.
    Regular Member 30ltr nutter's Avatar
    dunstable
    hi i have a similar noise which i think is the vacumn pump drive it sounds like a tappet but if i pull the vacumn pump pipe off the noise goes away reconnect it and it comes back so i think it the pump or drive also got a harrsh engine noise at the same time i wonder weather the two are connected in some way
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    What was it then? Mine's doing it too...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by simac View Post
    Water pump is actually driven by timing belt, NOT auxilliary belt.
  1. Ticking noise from heater
    By conman in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2013, 15:04
  2. ticking noise when air con on.
    By philc1210 in forum Engine & Drivetrain
    Last Post: 30th July 2011, 20:42
  3. ticking noise
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 21:07
  4. Ticking noise
    By trickyjacks.4 in forum Engine & Drivetrain
    Last Post: 23rd February 2011, 15:33
  5. Ticking noise
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2007, 19:08
