Thread: Service code?
    India
    Default Service code?
    My trip odo flashes lnSP for a few moments when I start the car. It then goes away. Is that the service indicator?
    Byas
    11 Post(s)
    Yes. InSP is the service light.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    means your car is due a service
    Time to get things changed oil, filters, check brakes etc good luck m8 ....
    India
    Thx for quick replies!!
    B
    Mileage : 000
    Yes. I think you will find your car has been programed fpr this to come up annually. To stop it doing it. If you turn on the ignition(don,t start the car, just get the ignition lights to come on). then holding the brake pedel down, press the button on the oddmeter (speedo) hold for a few seconds, that should rest it till next time.
    Apr 2009
    London
    Quote Originally Posted by ed taylor View Post
    That does not work for my vectra
    May I done wrong somthing
    After few seconds it comes to numbers
    1.7
    00 1 04
    what that means ?
    11 Post(s)
    Quote Originally Posted by sukisti View Post
    1.7
    00 1 04
    what that means ?
    The sequence you were given is wrong. You need to hold in the trip (and possibly the brake pedal down - see below) BEFORE turning on the ignition.
    Ignition Off
    Hold Trip Reset In (keep held in)
    Turn on Ignition
    Still Hold Trip Reset for approx 12 seconds, the InSP should change.
    release trip reset.
    switch off ignition
    switch on ignition and check.
    If that doesn't work, then with your car you *might* also have to press the brake pedal.
    Ignition Off
    Press brake pedal (and keep pressed)
    Turn on Ignition
    Still Hold Trip Reset and brake pedal for approx 12 seconds, the InSP should change.
    release brake and trip reset.
    switch off ignition
    Apr 2009
    London
    Thankyou Big Dave problem solved
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I assume you have actually done the service actions required, and not just simply turned off the indicator????
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  3. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  4. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  5. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
