Results 1 to 10 of 15
Thread: tyre pressures
    Full Member gibbon7000's Avatar
    lincs
    Default tyre pressures
    Can anyone tell me what the correct tyre pressures should be for 235/35/19's on a 2.0T signum facelift under normal load conditions????
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i use 40 allround ....rule of thumb twice the wheel size plus 2
    lincs
    Quote Originally Posted by soulman View Post
    Really.......that much.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i use the double the wheel size as well but i don't add the 2
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    for the Vec I think its front 39, rear 35
    lincs
    Anyone else wanna add anything???
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    my 17's have double the wheel size plus 2 so i am running 36 front and rear.....rule of thumb for it mate....so for you min 38 max 40....hth
    Midlands Mod Shop - NFFC.
    lincs
    Quote Originally Posted by ditchp View Post
    Thanks guys better get em checked tomorrow, as i'm sure kwik fit would ***k it up and probably put 30 in
    Oct 2007
    Midlands, UK
    I don't see what the rim size has to do with it.
    Working out tyre pressures that way infers you are compensating for the volume of air inside the tyre. But you are ingnoring the tyre tread width, which would have a much greater proportional effect.
    Pressure is pressure, and is measured "per square inch", so the wheel size, (and hence the contact area with the road) is taken care of.
    What really determines correct tyre pressures is the load they have to carry, i.e. the axle weight of the car. Hence you should use a higher pressure when "loaded", not because you fitted bigger rims.
    west sussex
    confused Ohhhh the pressure gets to me!!!!
    Hi there i'm new to this forum today & was wondering what the exact tyre pressure is for my 235/35 ZR 19 Y on my signum 2.2direct both fully loaded & normal? reason for asking my manual said 32 psi all round & since it has felt heavy in handling & steering!
    Thanks Rocketer
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
tyre pressure for vauxhall vectra 2.2 sri direct
