Results 1 to 10 of 14
Thread: Replacement Gas Hob Ring Thing!!
    May 2008
    Doncaster
    Default Replacement Gas Hob Ring Thing!!
    I feel like an idiot but what's the correct name for the rings that are on a gas hob top.
    I've got 4 rings of varying sizes and one of the rings has lost the little top thing that pushes the gas out of the sides of the ring.
    What's the top thing called and failing that, what's the name of the whole thing that I can search for to buy a replacement!
    The whole things lift out and I'm sure you can buy replacement ones?
    I don't even know how I lost the thing in the first place!
    EDIT: Everytime I search for gas hob it comes up with £100 whole things but I just need 1 ring!
    I put a search into Google & this could be a start 'gas hob ring burner spares' HTH .....
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Burner Base is the silvery bit that distributes the gas.
    Burner Cap is the brown/black cap that sits on top.
    Usually to contact the manufacturer of the hob is the only way to get replacements.
    It's annoying but spares are easy to come by if it's a recognised brand (Neff, Bosch, Hotpoint, Baumatic etc etc etc)
    I work in domestic appliances so hope this helps.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Get the manufacture and oven spec/range number up on here and we will have a nose for you.
    Wat else to do on a friday night?
    May 2008
    Doncaster
    Quote Originally Posted by John C S View Post
    Thanks guys for your help!
    That's the bit / part name I'm looking for so at least now I've got somewhere to start!
    Unfortunately my oven is a unknown (to me anyway!) weird brand called QA
    It's probably the cheapest crappest oven ever but does the job for me so didn't ever replace it! It was in the house when I bought it.
    It's an electric oven with a gas hob top bit. I don't know how the burner cap got lost but when I noticed it and asked the girlfriend all I got was...
    So, I'm hoping a replacement is easy to find!
    May 2008
    Doncaster
    After a bit of digging I think my QA oven might be a Hygena rebrand?
    If it is I found this might be the right thing:
    http://www.espares.co.uk/part/cooker...b-burner-.html
    Not too sure but not as expensive as I guessed it might be!
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    nick , do you have a large burner , two medium ones and a small one , as i may be able to sort something for you
    May 2008
    Doncaster
    Quote Originally Posted by SteveH View Post
    That's right yeah!
    I mistakenly thought it was the small one I'm missing but it's actually one of the medium ones.
    Are you able to source any of the medium ones Steve?
    Thanks!
    Apr 2006
    Wigan
    Yes nick , but im only back in work monday , i will sort you one out and post it too you , PM me your address
    May 2008
    Doncaster
    Thanks a lot for your help Steve that's really appreciated!
    You'll have to let me know how much I owe you for it.
    Nick
  1. O-Ring
    By Tam80 in forum Engine & Drivetrain
    Last Post: 7th February 2011, 10:09
  2. 360-Red ring
    By MLC in forum Games Room
    Last Post: 8th June 2008, 08:19
  3. XF at the 'ring
    By MattB in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 19:00
  4. For those of you who like the Ring
    By AJA in forum General Chat
    Last Post: 13th June 2007, 12:45
  5. me on the ring
    By vectra 2.0 t in forum General Chat
    Last Post: 13th August 2006, 12:14
