Thread: 3.2 Signum vibration under power - ideas?
    Feb 2007
    Gunnislake
    Engine : 1.9 CDTi 120
    Default 3.2 Signum vibration under power - ideas?
    My Signum 3.2 (160k miles) has developed over the last 1500 miles a vibration when under power (not on over run) the frequency seems to be more road speed than engine speed. At first thought it might be engine mounts with engine vibrating on the body but they dont look too bad.
    Looking underneath there is a split inner CV boot on the shaft that extended from the box other wise all looks OK.
    Any clues?
    Regular Member poves's Avatar
    lancashire
    Not sure mate , but I have a full set of mounts for sale if you need em , 41000 miles.
    scotland
    Had a similar problem with a BMW, ended up replacing the front control arm/wishbone bushes, problem solved. Worth having a look.
    newcastle upon tyne
    my advice is get it into a garage asap. cv boots contain greese, if they split joints can quickly dry out, over heat causing a vibration. if left to long u risk damaging drive shafts. good luck
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by idobigmls View Post
    C**P!!!!!
    that's probably the cause of my vibration!
  1. z20net power problem any help or ideas needed
    By roc in forum Engine & Drivetrain
    Last Post: 10th February 2017, 11:59
  2. Intermittant vibration through steering wheel....any ideas?
    Last Post: 23rd December 2012, 20:15
  3. Just bought a 1.8 03 elegance, any ideas of improving power, cheers
    By cruicky27 in forum Petrol Engine related
    Last Post: 19th May 2010, 11:26
  4. My Signum has an annoying vibration
    By eley1 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 21:24
  5. Signum engine vibration
    By jstal40024 in forum Engine & Drivetrain
    Last Post: 9th December 2005, 19:39
