Thread: clunk / knock when braking?
    Default clunk / knock when braking?
    as above.. can be felt through pedal sometimes i think....
    sometimes as soon as pedal is pressed, sometimes just as the car stops.
    got an idea myself, but want others opinions of causes.
    Northampton, UK
    Do you only get it when you have to brake quite hard? Or from a high speed?
    Ashington, Northumberland
    Check caliper carrier bolts are tight and caliper to carrier slider bolts.
    Quote Originally Posted by n_hudson View Post
    any speed but doesnt always happen....
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    if it does it when just about to stop, it could be 1 of the ABS rings split, or as gary said check your caliper bolts
    Regular Member GoldenWonder's Avatar
    Durham
    I used to get a similar noise when I used third party brake pads on my Omega (apparently they fit about 10 different cars!) and it was cured when I used Mintex pads.
    Maybe the pads moving slightly in the caliper frame if they're not a perfect fit?
  1. Boot clunk/rattle/knock
    By slinky270306 in forum Bodywork & Interior
    Last Post: 8th September 2012, 19:53
  2. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  3. Clunk when braking.
    By Smaddoc1 in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2011, 22:20
  4. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
  5. Knock/Clunk when taking up drive Rev/Fwd + Squeak from Front N/s ??
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 18:40
vectra c clunk when braking hard
