Results 1 to 10 of 13
Thread: bonnet release
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Default bonnet release
    Is there a fault with the bonnet release on the vectra i have owned 2 now and the catch will not pop the bonnet open you have to hold it and have someone else lift the bonnet
    Sunny Dartmoor
    I had the same problem with mine when i got it,i just lubricated the spring and catch with grease and not had a problem since............
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    there is also a cable adjuster under the bonnet too, undo the screw pull the cable tight and do up the screw worked for me
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by magpie27 View Post
    Mine is the same, its so bad that after I pull the lever, I can wedge my finger underneath the bonnet and open it.
    Gazza4
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Regular Member old cruiser's Avatar
    slough
    Had the similar a few weeks ago, but couldn't open it at all at first , took me around 30 mins , by pulling lever then pushing and pulling on bonnet until finally popped it, greased catch in slam panel and all around catch on bonnet itself, in fact anything I could see relating to the catch got greased, now it's good as gold.
    Cheers Pete
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Where abouts is this screw mate
    My bonnet release is quite slack is this preferable I wonder? ............... :ranger;
    once you have open the bonnet you will see the cable with a black braket on it, which hooks into the slam panel and at the bottom of it is a self tapper screw
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As Glynn says, loosen this screw, slide the outer slightly tauter and tighten the screw - no more issues.
  1. bonnet release
    By Pete Elite in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2015, 00:27
  2. bonnet release cable,,,AGAIN!!!!!
    By collyb in forum Bodywork & Interior
    Last Post: 25th June 2012, 08:49
  3. 2.8V6 bonnet release ....do it now !!
    By Deztroyer in forum Bodywork & Interior
    Last Post: 14th June 2011, 22:45
  4. Bonnet release
    By Admishere in forum Bodywork & Interior
    Last Post: 23rd March 2011, 15:26
  5. bonnet release
    By ade0303 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 20:39
