Thread: reverse parking sensors
    Question reverse parking sensors
    Hi Guys
    I have just bought an aftermarket, set of reverse parking sensors off ebay in case my missus drives my signum, I was hoping to fit the sensors in the black plastic under the painted section of the bumper, This part of the car is only 40cm off the ground, and the manual says to put the sensors 50-65cm, this is on the bootlid so im not going to do that. Do any of you have experience of these kits or if you have factory fit sensors on your cars how high are they?, also I have to connect a wire to the reversing light, can anyone tell me what colour the reversing light wire is.
    1 final question, in the boot behind the grille for the l/h rearlight I found some sort of multi connector can wrapped in foam on the end of a loom can anyone tell me what this could connect to?
    cheers
    Stu
    ive fitted after market sensors ive put mine on the same level as the number plate.take look a my pics you should see them.any questions p.m me mate. i will look wich wire for you tomorrow
    Cheers mate, did you spray them yourself?
    I had a Vx aftermarket kit put on my Signum. They went on the bumper i.e the painted section. I certainly wouldn't put them on the black lip as I can't see how they be kept held in place on that section.
    My dealer had a bit of fun fitting them which resulted in Vx modifying the instructions for dealers!!! I'll post the details when I have a bit more time.
    As for the connector in the rear area - sounds like the connector for the towbar electrics.
    i got a set of cheap sensors and fitted them my self very scary drilling holes in bumper put mine in line with number plate very easy wiring only two wires have been on for 3 months and still work not bad for £10 !!!!!!
    mine came in silver so no spraying for me.mine cost £46 off ebay and fitted myself.everybody thinks it is the factory fitted ones.so iam well pleased
  1. Cheap reverse parking sensors
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:06
  2. Reverse Parking Sensors - Signum
    By daba in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 18:03
  3. Parking kit reverse sensors
    By jlb777 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2008, 11:30
