Thread: ABS Light
    Regular Member rickit's Avatar
    Biggleswade
    Default ABS Light
    The ABS light on my 1800 Club comes on when you start the car and then goes out as it should after the self test, only to come on again and stay on after about 30 seconds to a minute. Has anyone had a similar problem ?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Maybe front wheel sensor wiring plugs, they get water / dirt in and don't function correctly. Worth an unplug, clean and reconnection.
    Otherwise it could be a wheel sensor gone south, which would need some diagnostic time to find which one.
    Biggleswade
    Have identified the reason for the ABS light coming on, it was due to the front pads being very worn. Have had the pads and sensor wire replaced and the ABS light is now off all the time.
    Quote Originally Posted by rickit View Post
    One happy chappy ...............
    Biggleswade
    Smile
    Quote Originally Posted by Tadpole View Post
    You bet sir
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Pad wear and ABS = not the same thing.....
    My guess is that what I said above has been disturbed during the pad changing process and now works..
    Biggleswade
    Quote Originally Posted by Ste View Post
    Hi Mate, Aye sir I know they are different, asked the garage that they unplugged and cleaned the connector as you suggested in your previous post. They said that they didnt and that they just changed the pads and sensor wire, whos knows mate but thanks again for your help.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
