Thread: vectra facelift offside headlight not working
    northampton
    Default vectra facelift offside headlight not working
    hi guys had a problem with the facelift c shape today
    the offside(driverside) dipped headlamp doesnt come on i have replaced the bulb have checked the wires going to the bulb between the socket on the light fitting for continuity and its good checked the plug and when the lights are turned on ignition aswell theres no voltage present
    checked fuses and they are fine cant quite see where the wires from the headlamp go to
    i am guessing they will go the body control module but where on this maze of components is it
    the car does not have xenon lights just normal halogens
    i have a tech2 system but its only for the earlier versions of vectras upto 2004 not the facelifts
    had problems before onj the car when the wipers stopped working and the car had a new ecu installed on warranty, shame its not still under
    any help would be much appreciated
    andy
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by madandyuk View Post
    Why's that? You must have the CANdi module for it to work on the Vectra C so why won't it work on the facelifts?
    northampton
    sorry i have the pc based version of tech2
    Vaux-COM? That's what I have and I've plugged into facelifts with no problem.
  1. Vectra facelift headlight
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 13th February 2012, 00:17
  2. Offside Heated mirror not working!
    By Vectra Singh in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 20:05
  3. Facelift vectra headlight removal
    By wilf2312 in forum Bodywork & Interior
    Last Post: 5th May 2007, 15:35
