Results 1 to 10 of 14
Thread: Clearing fault codes
    scotland
    Default Clearing fault codes
    Hi GUys,
    Anyway to clear a fault code without having access to a fault code reader.
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Nope.... unless you use the limp mode re-start technique.... key in ignition press break and trip reset etc... there's a thread on here about it....
    I think after a certain amount of starts codes clear yet you need to access the ECU to clear codes straight away....
    scotland
    Its the emissions light that is stuck on after i removed and cleaned the egr valve, also did the change to the swirl valve linkage and cleaned the boost valve! Spanner light came on initially but then went away and now the emissions light is stuck on!
    Seriously considering a ford mondeo!
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Quote Originally Posted by Stevie-B View Post
    This is the service light reset procedure, not the fault code/limp mode reset.
    yep - after a number of successful restarts without the fault coming back the light will go out (think its 40-odd starts) - or as above a code reader will clear it straight away.
    Quote Originally Posted by oxenburger
    hmm, emissions light - not sure about that one! Over to others more knowledgeable...
    Disconnecting the battery for a bit will get rid of the emissions light. As long as it doesn't come back on again then nothing to worry about.
    Melbourne, Australia
    Hmmm... I thought the light should turn off once the fault has been fixed, even if the code is not cleared...?
    May 2006
    scotland
    You can leave it be. As long as the fault does not re-appear, the lights will go out over the next month of normal driving (something to do with the code being overwritten when a cyclic memory buffer reaches that memory location where the fault was stored. As you drive, the memory keeps getting written to and eventually old data is overwritten with new)
    scotland
    Fault code went away this morning!
    The connector to the egr valve was loose last night Drove around hoping it would go away! (didnt)
    Got up this morign turned the car on and its ****ed off lol!
    Jan 2010
    Glasgow
    I have just found and registered for this site. I feel somewhat ignorant of the terminology being used but it seems that my problem(s) seem to be identical. I hope that somebody will be patient and explain matters in simple terms or direct me to where I can read up and become more familiar with the terminology. Thanks in anticipation.
    I have a diesel SRI bought as a nearly new. About 2 weeks aftre service and first MOT (ie just out of warranty!) yellow spanner came on repeatedly particularly when towing caravan. Switching ignition off and on cleared it. It vanished again for the winter months but on again just before recent service. car was running a bit lumpy and very slow from low revs. The day before the service the yellow engine light appeared though car seemed less lumpy!
    Just back from service and MOT and invoice says "engine man light won't reset, fault code P0400 EGR valve. Still seems slow from low revs especially when cold.
    If anybody can advide or explain in simple terms, I would be very grateful.
    Dave C
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Code points to Egr so i assume its the problem especially with it being slow from low revs,best bet it to either clean the egr valve or replace.
    I assume you have a 19cdti SRI your profile says 1995 so i'm guessing that's wrong,there is a how to that explains how to clean the Egr valve and replace
    Irmscher Insignia CDTI 130
  1. Fault finder/clearing and skill members list
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 12:59
  2. help with fault codes
    By bobsimes in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2011, 06:42
  3. Fault Codes
    By cosmic in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2010, 15:35
  4. clearing error codes
    By shadow.warrior in forum Engine & Drivetrain
    Last Post: 26th July 2010, 13:35
  5. Help with EGR fault clearing please?
    By johnny_M in forum Engine & Drivetrain
    Last Post: 27th May 2010, 22:14
