Thread: billstein b4 problem
    durham
    Trim : Leather
    Default billstein b4 problem
    hi, am replacing my front struts with the b4s and have come across a problem, the b4s dont have the upright piece of metal to fit the pad sensor wires onto! so where did you guys fit it? (its a square plastic block grey in colour) thanks tony.
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    A little bump back up, anyone help? I got a V6 and would also be looking at upgrading suspension
    Regular Member leonvectrac's Avatar
    south shields
    can you not cable tie them up some wear??
    Belfast
    If it's anything like the Astra, that clip is a seperate piece of metal rusted on to the original shock. It'll pull off and goes between the shock and the hub bracket.
    durham
    Trim : Leather
    cheers guys, no the metal is a part of the piece thats welded onto the suspension leg, the brake hose also goes onto this , that was fine just had to open out the hole slightly to allow the hose to go through, but nowhere to attach the electrical block to, and it is a block, quite big, so to you big lad what i did was hacksawed off the original metal lug its about 1 and a half inch long, and welded it to the new leg and all is well a dab of black paint and looks as it should be but surely it should of came with this!! i cant believe no one has not come across this before, or ive got bad legs from billy. i suppose you could just tie it up but i would of thought that would then fail the mot, and i wanted it done right, thanks tony.
  1. Rear Signum Light problem problem - help
  3. Billstein b4 Front Shocks.
    By macdad in forum Handling & Braking
    Last Post: 28th August 2011, 20:46
  4. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
