Thread: Where did you mount your Ballast?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default Where did you mount your Ballast?
    Fitted my HID kit today. Passenger side ballast was easy to fit, stuck it inside the battery box. As for the drivers side there is nowhere to fit them properly. No room under air box, inner wing, nothing. I ended up using the supplied holders and bolting them onto the air box using one of the air box's own bolts. So where did you fit yours?
    Regular Member leonvectrac's Avatar
    south shields
    i got mine up the side of the wing
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    mines tucked under the headlight/inner wing on the os a very tight fit. if your still having problems let me know.
    Jul 2006
    I found that there was a natural hollow between the back of the headlamp unit and the inside of the wing, my ballasts and ignitors are stuffed in there.
    Having said that, my parking sensors don't work with the HIDs on...
    Regular Member Robbie69's Avatar
    inside the wing as above.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Mines fitted inside of the wing too....
    Regular Member Zark's Avatar
    Herts
    lke everyone else, slid down inside the wing.... do the ballasts produce any heat though?? It's presed up against the outside - don't want to find any paintwork problems later...!
    Quote Originally Posted by Zark View Post
    Not had a problem so far, there has been a ballast in there for a year!
    playing with spanners
    taped up to the back of the light lol
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by bobby-tupper View Post
    Cheers for the offer mate
    Yea I looked at the inner wing and TBH its the tidiest place for it, but didn't want a dull blow say from a football to knock it off. Where it is now isn't the most practical but its not going to shift as its bolted in. When I have a bit more time I think i'll take the hole headlamp out and try for a better place. If I can get it on the outside of the inner wing away from the outer wing then think that would be Top Trumps.
  1. HID ballast
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 13:57
  2. Spare ballast?
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 01:21
  3. Where do you mount your HID ballast?
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2011, 20:20
  4. Location of HiD Ballast
    By Ginge7289 in forum Styling
    Last Post: 6th February 2011, 00:24
