Thread: Damp!!
    Regular Member ballan22direct's Avatar
    isle of lewis
    Default Damp!!
    Having major damp problems in my boot round the wheel well. anyone had this problem? as i cant see water coming in anywhere. had a similar prob with my old vectra B through the rear wiper but all seems well round there.
    Someone I think had the same problem & found the end caps of the roof runner trim were to blame. Hope this helps ...
    isle of lewis
    cheers tadpole. check that out tomorrow.
    Quote Originally Posted by ballan22direct View Post
    This could be a good place to start as I think this sorts it out in the end or at least sends you in the right direction http://www.vectra-c.com/forum/showthread.php?t=38539 ..
    isle of lewis
    your welcome m8 ..
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    It could be one of four problems which cause this:
    1: Rear lights
    2: Rear Quarter Light Windows
    3: Aerial base seal
    4: Rear roof runner clips
    I just had the same issue and found it to be the roof runner, the rivet that holds the clip in can bee loose and lets the water in, I cleaned it out(was full of dirt) and put a bead of silicon sealant around the clip and on the rivet.
    Dried out the car (make sure you dry out all the C column) and hey presto, leak solved. I also re-sealed the quarter light glass just incase.
    HTH
  1. Damp smell ?
    By m8wos in forum Bodywork & Interior
    Last Post: 10th January 2013, 19:34
  2. Damp gearbox, need some help!
    By Chip in forum Engine & Drivetrain
    Last Post: 13th May 2012, 23:10
  3. Damp Smell?
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 23:23
  4. Damp problems...
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 22:57
  5. Damp door
    By mariusbuk in forum Bodywork & Interior
    Last Post: 8th December 2009, 16:27
