Thread: Handbrake adjuster?
    Regular Member thewww2's Avatar
    London
    Default Handbrake adjuster?
    hello all
    can anybody tell me where the handbrake cable is adjusted from , is it at the wheel end or from inside the car near the handbrake lever?
    thanks
    I thought it was self adjusting at the lever end? Didn't think there was anything you could do to adjust it yourself?
    Wiltshire
    Don't think mine works then. It nearly touches the underside of the armrest, it comes up so far. (not that I care!)
    Preston Area
    mine does that as well, even thought he rear brake pads are brand new.. final click then the brakes are on...a little disconcerting..
    London
    mines a bit too high too it lifts the armrest when fully applied, im an mot tester and if it came into me like that i would be on the verge of failing it.
    Regular Member mel's Avatar
    tayside
    possible problem with the caliper......
    was in VX today to get my handbrake adjusted and they had a look at it and said the caliper was needing replaced......
    warranty fix
    Regular Member cpt slow's Avatar
    In a house
    Quote Originally Posted by thewww2
    hello all
    thanks
    Its adjusted automatically via the toothed wheel on the rear brake setup. Which is why you have to wind the rear piston in rather than push it when renewing the pads .
    If its not holding car either the cable has stretched , or the automatic adjuster on the back brakes ( one each side) is faulty .
    Blimey this is an old post isnt it ?
  1. drivers seat adjuster
    By jimmyred in forum Bodywork & Interior
    Last Post: 30th April 2013, 21:24
  2. The hand brake adjuster.
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2012, 18:32
vectra c handbrake adjuster
vectra c handbrake self adjuster
08 vectra handbrake adjustment
