Results 1 to 3 of 3
Thread: Power steering problem - need advise please
    Regular Member Ant SRi's Avatar
    Merseyside
    confused Power steering problem - need advise please
    Hi,
    Not had any toruble with PS until today - on motorway.
    Yellow steering wheel light on dash came on and suddenly and steering went heavy.
    Got car picked up and am just looking at it now.
    When I start it up most of the time the light is off and the PS pump can be heard running. However if I leave it for a few mins, the pump stops and light come on. Then another min or two and come back on again, this keeps repeating..... (this is with the car stationary btw)
    I've checked PS fluid level - and is fine. Checked all the wiring plugs to the pump and the one to the rack - all seem okay and clean. Removed and re-insterted fuse F9 too.
    The problem still happening - pump keeps switching on and off.
    When the pump is running the steering works fine, and pump can be heard speeding up and slowing down so I dont think its a load issue with a bad rack for example.
    Has anybody seen this before or know what it might be.
    Ant.
    Merseyside
    Arrrrgghhh frustraiting!!
    I've got the bumper off so the pump is accessable. It blips on and off just as it would if there was a loose connection but I've traced it all back and it's good. And I've wiggled / knocked every thing too...
    Two big main power cables straight to battery, one wire to the sensor on the rack and another multiplug going into the car (to ECU i presume)
    Merseyside
    Oh and no fault codes are stored in the ECU.
  1. power steering problem?
    By bigbrox in forum Engine & Drivetrain
    Last Post: 6th May 2012, 19:33
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. Another Power Steering Problem!
    By PAD_D in forum Engine & Drivetrain
    Last Post: 31st July 2011, 09:16
  4. power steering - problem?
    By wardy in forum Suspension, Wheels & Brakes
    Last Post: 31st August 2008, 17:55
  5. Power Steering Problem
    By marcel1 in forum Troubleshooting
    Last Post: 23rd August 2008, 15:39
