Results 1 to 10 of 20
Thread: first 4 wheel alignment
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Thumbs up first 4 wheel alignment
    Just booked my car in for a 4 wheel alignment at a garage in Derby for next wednesday (18th), with the hunter system. Guy sounded real helpful on the phone.
    only just got round to bookin it.
    I hit a kerb tryin to get out of my road when it snowed and now my steerin wheel is slightly off centre when goin straight. the road is up a slight hill, and the it cambers. its a cul-de-sac aswell, so the gritters dont come down.
    My wheels started spinnin half way up the raod, and as they did i started slidin towards the kerb. I couldnt do anything to stop it.
    I bumped the kerb which pushed me forward a bit givin my tyres a bit of grip to get me up the rest of the road. checked the wheels, and theres a bit of a graze to the lip, hung out the window to see if i could see if it was bent, but looks fine.
    got under the car last night to check to see if i could see anything bent/cracked etc. all looks fine.
    This is the first proper (garage) alignment the vec has had since i got it (jan 2005).
    When i fitted the coilovers i could find anywhere local that could set it up for me due to the lack of wheel/arch gap. so i set it up myself.
    I first set the camber on the rear to be as close to 0 as the standard adjustments allowed, which isnt very close to 0. then i adjusted the eccentric bolts slightly for a rough tracking alignment.
    Did the same for the front. set the camber so the tyres didnt rub on the inner arches, this camber adjustment seemed to set a nice toe measurement aswell. Had these settings for 3 years now on 3 sets of tyres.
    There is a some inner tyres wear on the rear (to be expected from the camber) but it isnt overly fast. the front is the same, slightly extra wear on the inner edges but again not overly fast.
    I do about 18,000 a year on average.
    Ill update this thread when Ive had it done to show the read out of the measurements and to let u all know how i got on.
    Regular Member silverhairedracer's Avatar
    ESSEX
    Had my veccy done as well on a Hunter system,you will notice a lot of difference believe me !
    Regular Member mark the hat's Avatar
    Jan 2008
    manchester
    hi just a quick question how much is it to get the aligment ????
    or do prices vary garage to garage .......rough price dont want to be paying over the odds
    cheers mark
    Im not sure. hes got to have a quick look at my car and see if he can do it (due to the suspension height). then he wil give me a rough price for checkin and anything that needs altering.
    He will be doin tracking and camber for me.
    Silverhairedracer: how much did ure alignment cost, if u dont mind me askin?
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    You should be looking to pay between £35-£45 for a four wheel alignment. Should take about 10-15 minutes and is well worth it.
    Jan 2008
    manchester
    cheers steve,carl........not bad atall
    mark
    ESSEX
    Quote Originally Posted by Stevie-B View Post
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    There's a big difference between 4 wheel alignment and a Full Global set up as per http://www.wheels-inmotion.co.uk/tec...ignsystems.php.
    My full global set up took an hour and cost £80 but well worth it.
    Carl - check to see if they load the front seats with weights to simulate loads on the suspension. If they do, then they should now what they're doing from there on in.
    East Midlands
    From what i can gather from previous threads,the cost for the hunter set up done through...alighnmycar.com is about roughly the cost of a new tyre,Carl funny you should mention that your steering wheel is off centre,so is mine did it the same way too,by hitting a kerb in the snow.....ps let me know how you get on cus i'll be doing the same after i fit the lowering springs...cheers.
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
Tags for this Thread
