Results 1 to 3 of 3
Thread: My ongoing leak saga...
    Hampshire
    confused My ongoing leak saga...
    Firstly thanks for all of the help you guys have provided already.
    Right...
    Good news. I know where the water is coming from
    Bad news. I can't figure out how it's getting there
    Ok, here goes.
    I have had a very wet front and back passenger side foot wells.
    I have removed all of the side trim on the passenger side of the car so can see most of the body.
    The water is entering the foot well from under the dash. I have taken the clove compartment out and basically stuffed every hole I can see with kitchen roll. The piece of paper in a square hole on the left hand side gets soaked.
    I know that is a bit vague, so I will try to describe the location a bit better.
    I have removed the trim on the left side of the passenger foot
    well and the glove compartment, on the left, immediately below what looks like an ECU there is a tubular metal square shaft, about an inch and a half long. This is where the water comes out. See circled area in this photo:
    Ok, here's the confusing part...
    When I get into my car after it has been raining all of the paper is dry. I gently pull away to the right, then turn sharply left, as I do this I hear loads of water swishing (is that a real word?) along somewhere to the right hand side of the car. I then take a sharp right and it all goes to the left and then pours out of the hole (in picture). Before any one says it, it isn'r the scuttle, I have been checking this constantly, and have now removed the two rubber 'Drainage' pipes to stop this getting blocked up.
    If I look behind the dash, I cannot see anywhere that the water could flow from Right to left, as there isn't anything that goes across the gap where the glove compartment should be, also it is very odd as there is nothing above the hole where the water could come from.
    I'm getting very confuddled by this now, any help or ideas anyone has would be very gratefully received.
    Many thanks in advance.
    Trev
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by TrevF View Post
    Is this a future Big Rich mod??? lol
    Hampshire
    Whoops, should be glove. I'm sure that cloves in a car is just going to stink beyond belief!
  1. ongoing CC problems
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 11:45
  2. ongoing additions
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 20:25
  3. Ongoing problem - P0340
    By Ste in forum Engine & Drivetrain
    Last Post: 4th December 2009, 13:01
  4. Ongoing Siggy saga
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2008, 17:48
  5. Ongoing saga
    By v6boy in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2006, 19:26
