Results 1 to 10 of 15
Thread: urgent help needed!
    Regular Member VectraMat's Avatar
    Hull
    Default urgent help needed!
    Hi guys. I'm just driving home from my gf's place but there's something wrong with my vectra.. I've driven about 10 miles now but the engine temp dial hasn't moved at all. The heater has warmed up but isn't as hot as it should be. Does anyone know what the problem might be. Thanks. Matt.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like thermostat mate.
    Hull
    Is this a big/expensive job mate? Cheers for the above btw.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    TBH, never done one on the Vec. In the past on other lumps its just undo two bolts, pop out thermostat and pop in a new one, plus draining and refilling coolant.
    Hull
    Cheers rushy, might have to spend tomorrow night investigating this then. Ta mate!
    Regular Member mattolly86's Avatar
    oxfordshire
    i've not done it on a veccy but i would be seriously suprised if more than 4 bolts involved
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Any noises mate? Could be the pump also, but that's a bit more involved. Thermostat should cost you no more than £40 for labour at any half decant independent. You'll still be under warranty won't you? The thermostats i've done in the past are usually in a metal pipe that comes of the lump. You unbolt the pipe and the thermostat is just inside and will fall out. Totally different cars but the principle will be the same. Pop it in a pan of water and it should open about 85-90 degrees, if not its broken.
    Regular Member RhayaderSax's Avatar
    Rhayader
    Yep - I agree. Sounds like thermostat. Replaced them on Cavalier A & B. If Vx design & manufacture is still similar if you do it yourself for god sake use a torque wrench. Casting typically held on with 2 bolts & the flange is the weak point. Over-tighten the bolts & the casting that the thermostat fits inside will crack.
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    This is standard on the 1.8's!
    Mine is exactly the same and if you do a search, numerous members have had the same issue.
    9 times out of 10 a new thermostat cures the problem.
    Snowman, you got your ears on?
    Regular Member dlm71's Avatar
    Cheshire
    I have the 1.8 vvt SRI and mine does the same! just never got around to sorting it!! it won't move for 10 mins or so then it will shoot up to it's running temp!!
  1. urgent help needed.
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 09:53
  2. URGENT help needed
    By vectraedition100 in forum Engine & Drivetrain
    Last Post: 27th February 2012, 20:21
  3. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  4. urgent help needed >>>>>>
    By justin79 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:02
