Thread: Belt change at 60000 2.0Dti?
    Devon
    Default Belt change at 60000 2.0Dti?
    My 2.0Dti needs it's service shortly (62k done). As I have no service history, should I get the belts (and which ones?) changed?
    And while I'm at it, should the pipe leading into the airbox be tied to the box are freely moveable in front of the inlet pipe? I noticed it was loose and halfway in front of it.
    Could this explain my reduced fuel efficiency?
    Thanks for any help!
    Mark
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    DTi's dont have a belt mate , they have a chain
    Devon
    Thanks Steve! I've learned something new today! This chain doesn't need changing then?
    East Midlands
    If you mean the pipe is free to move,ie not fully secured ..then it should be...need to see some piccies for more clarity i fear.
    Devon
    Yes, the 3-4 inch pipe that takes the air from the front into the airbox is not secured and you can move it up and down and look into the airbox. It's a bit dark to get a good picture but I guess I need a cable-tidy to secure it?
    Devon
    As you can see from the images, the pipe leading into the airbox is not secured. Would this explain poorer MPG?
    I have now tried to secure it using a cable tie but it is not that tight. I guess I need to use those metal ones?
    Ah well, as said, it needs its 60,000 service so let the garage take care of it.
    East Midlands
    Yep the pipe in question should be airtight,and you need the proper jubileee clip for it.
    Devon
    Thumbs up
    Cheers! I'll probably be cheaper off buying them somewhere else than lett VX charge me for it I guess.
    The other side of that pipe connects to the piece of plastic sticking through the grille; should there be a clip on that end as well?
    Thanks again,
    Mark
  1. 2.0dti water pump/belt removal and refiting
    By gjsteed in forum Engine & Drivetrain
    Last Post: 16th August 2011, 19:43
  2. ??How 2 Change Crank Sensor 2.0DTI??
    By shatz in forum Engine & Drivetrain
    Last Post: 28th October 2008, 13:55
  3. Timing Belt or chain on 2.0DTi
    By John3v36 in forum Engine & Drivetrain
    Last Post: 7th August 2008, 20:02
  4. oil change 2.0dti
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2008, 10:50
  5. 60000 mile service
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2007, 09:14
Tags for this Thread
