Thread: new vectra c problem guys. help??
    halifax
    Default new vectra c problem guys. help??
    changed 2 doors on the drivers side, disconnected the earth. but co nected it back up properly.
    anyways now my central locking will lock all doors as it should but wont open the drivers door
    why is this happening to me guys?
    help would be appreciated.
    ta
    Regular Member Jackvectra18's Avatar
    Winchester
    have you connected all the plugs? lol, might need to be re-programmed m8.
    halifax
    Quote Originally Posted by Jackvectra18 View Post
    why? how?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Have you put the right module on the right door? Does it open on the second blip of the key?
    halifax
    whats all this door module thing about. i never change modules around. the new door just had its own
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    you need 2 make shore you have 0 volts there is no eearth on a car its neg volts so test it with a mulitmeter mate if you got 0 volts all i can think of is open the plug and spay contact grease on it hope it helps
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Quote Originally Posted by vxr View Post
    It might need programming to YOUR ECU then, tech2 job only.
    Regular Member darko2301's Avatar
    Croatia
    did you think of putting the module from old doors on new doors ?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the door module is part of the imobo system the key is programed to it and works the cdl system ...if you were to have a fault in another system you would loose the car totally (it would not start disconect both front doors to get the same fault)...you need to find the original door module and refit it so the key will work the cdl ...
  1. Vectra wiper problem - any advice appreciated - Vectra C
    By newbreed in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 20:57
  2. I have a problem guys
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2010, 18:02
  3. My vectra has gone guys and i have moved on
    By Auto-Brite in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2009, 19:02
  4. Problem...? Vectra SXI...problem with starting after filling with fuel?
  5. rear brake problem guys
    By gaz130 in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2008, 12:04
