Thread: Bilstein B4's on an SRI
    Regular Member Ben999's Avatar
    Milton keynes
    Default Bilstein B4's on an SRI
    I need to replace the springs on my 2.2 SRi and will be putting on the APEX ones from LMF (lowers by 30mm, although around 15mm on the SRi). My last MOT said that I had a weak rear shock, so before it's due I was planning to replace them with the Bilstein B4's. As the SRi is 15mm lower than standard and then a further 15mm lower with the new springs, will the B4's work fine on the SRi. The B6's are well over 3 times the price. So even if the B4's wore out quicker, would need to have to replace them 3 times to make up the cost.
    So would the B4's be fine on an SRi model?
    cambs
    Quote Originally Posted by Ben999 View Post
    they will be fine m8
    most have done the b4 with 30mm drop.
    Regular Member mat100edt's Avatar
    south coast
    superb shocks, i dont have mine lowered yet but i do have rear b4 shocks and what a diff to the standard rubbish vauxhall put on there. dont think your be dissapointed with them performance wise. hth
    Cambridgeshire
    So they are definatly safe enough to put with a 30mm drop spring? I was thinking of getting these myself
    Regular Member cookiejar31's Avatar
    Jan 2008
    leicester
    yes its a good set up. got mine done at the weekend and cant fault it. the ride is so much more responsive. would definatly recomend it.
    south coast
    well i think the SRI's (which i have) are 15-20mm lower than non SRI's and mine is fine so i cant see as a few more MM will hurt it, i wouldnt drop it on standard shocks as they dont function with rest of standard setup let alone with more constant pressure on them lol
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There have been a few reports of B4's crashing on lowered SRi's. They are the same length as stock LS/Club shocks, so your really taking them to the limit putting them on lowered SRi set up.
    Regular Member MrT's Avatar
    Near Durham
    It was that reason why I want to go for B6's - then everything suspension-wise seemed to hike by 30% about a month back...
    Once you end up paying for B6s and Eibach Pros, there's now very little price difference between the total price and one of the junior coilover kits from LMF - just to add that into the mix!
  1. Eibach Pro's + Bilstein B4's
    By VectraElite 2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 14:19
  2. Bilstein b4's
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 12:05
  3. Anyone Fitted Bilstein B4's to a Vec SRI/Signum Design?
    By snapsnap in forum Handling & Braking
    Last Post: 25th May 2010, 20:18
  4. Eibach Pro and Bilstein B4's
    By MattW in forum Handling & Braking
    Last Post: 18th March 2009, 10:26
