Thread: Fault Codes. Hypothetical Question!
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Default Fault Codes. Hypothetical Question!
    Just a thought... has anyone ever induced a fault code deliberately say by unplugging a item or say jamming the swirl bar or similar in order to get something replaced under warranty. ie. before the warranty expired.
    Example... car not displaying any fault codes but you know a certain item is on the way out, so to get it replaced under warranty you cause a fault code for the item concerned.
    Purely Hypothetical of course.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    theres a old saying if it aint broke dont fix it ....so why break it just to fix it .....
    Apr 2008
    In UK
    Quote Originally Posted by benny View Post
    I did say it was a hypthetical question, but for example the EGR valve will often result in poor performance and rough running often for many miles before it will put up a fault code. Same for badly worn or sticking swirl valves, and likely other bits too. Many VX dealers wont replace anything unless a fault code is staring them in the face, and then once the warranty expires the owner may be liable for a very large bill, which may have been done under warranty just a few weeks earlier had there been a fault code showing for said item.
    Not ethical I know, and not something I would ever dream of doing myself of course, I merely wondered whether anyone on here had done this in the past.
    IOW A bit like taking something back to PC World with a very intermittent fault. You will have more chance of winning the lottery than getting it replaced. However, if you take a item back and state thats its blown up or caught fire, you will find its replaced without any hassle...
    Purely HYOTHETICAL remember.
    [Ex]Admin Duncan's Avatar
    Well if a dealer replaces a part based purely and simply on a fault code without any further investigation then they're the idiots.
    Also how can you be sure you'd get the desired fault code to appear anyway? - unplugging something, for instance, is usually going to bring up a different code than if it wasn't working properly.
    Quote Originally Posted by Cameron43 View Post
    Now come on - make yer mind up! - which one is it to be? Admitting to it or hypothetical?!
  1. Fault codes
    By SarahP in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 17:37
  2. Fault codes
    By GSi-Col in forum Engine & Drivetrain
    Last Post: 26th May 2012, 10:20
  3. Fault Codes
    Last Post: 28th April 2012, 19:02
  4. 3.2 Gsi fault codes
    By Spelly in forum Engine & Drivetrain
    Last Post: 4th May 2011, 16:55
  5. fault codes
    By scoobyman in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2008, 20:13
