Thread: Aftermarket Stereo CD Fitting
    Somerset
    Default Aftermarket Stereo CD Fitting
    Iíve just purchased an aftermarket stereo, bought it from Maplin, one of their Bluetooth, MP3 jobs, but having a little bit of a problem.
    Basically I have purchased one of the standard ISO loom adapters (eBay), plugged it into the loom and stereo to check it all works before fitting, and the red LED security light flashes on the stereo, and the on button glows, but when I push the on button nothing happens.
    The ISO adapter seems to be exactly the same as the Vauxhall plugs, it just has the red and yellow leads swapped as far as I can see, so I tried not using bypassing ISO adapter, and it does exactly the same, however the red led glows a lot brighter, but still does not turn on, maybe it is getting more power now.
    Am I doing something wrong? Or does it sound like a faulty unit?
    The car is a 2002 DTI SXI.
    Any ideas? I have read about needing to take power from cigarette lighter, is this instead of using the yellow wire from the loom?
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    You need to take a feed from the cig lighter on the back of it there is a small connection taped to it on the iso lead you should have a loose wire with spade connection on it connect this to the connector at cig lighter and should power up as the old head unit has 4v to power it up the new one take 12v to power it hope this helps you.
    Edinburgh/Catterick
    Only problem ive got you've got to turn the stereo off manually bud but mine powered up straight away
    Somerset
    Hi Marc, Thanks for your reply.
    This must be the problem as i have just plugged it into our clio and the head unit powers up fine.
    The new head unit does now have a loose wire, all of the wires go directly into the adapter. The ISO harness which i purchased from ebay also does not have a loose wire.
    I presume it will be finding which wire it is in the adapter and taking a snip of it. Will it be the constant 12v or the ignition 12v which needs to come off the cig lighter?
    Edinburgh/Catterick
    The constant 12v supply i think yellow plugs into the adaptor on the back of cig lighter
    Edinburgh/Catterick
    Your instruction manual for your new stereo will tell you what colour it is
    Somerset
    Excellent, i shall have a play with that.
    The stereo says - Red (12v) Power, Yellow (12v) Memory
    Regular Member signum junkie's Avatar
    Edinburgh
    Def the problem m8 I had same happening until I realised that VX stereo was lower power input
    Regular Member Middo's Avatar
    Swindon
    What they said
  1. fitting aftermarket single din stereo to preface, whats needed?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 14:54
  2. Aftermarket stereo fitting
    By datcat101 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 22:22
  3. fitting an aftermarket stereo checklist please
    Last Post: 19th July 2011, 10:17
  4. Aftermarket stereo
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2010, 15:20
  5. aftermarket stereo
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2008, 22:26
edinburgh aftermarket stereo fitter
