Thread: Snapped Bolt
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Snapped Bolt
    I was tightening the wheel bolts after washing my car yesterday and one of them snapped in the hole! How can i get the remaining bit out? Can it be pushed through and out the other side or will it need drilling out?
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Maybe either. If the bolt never went all the way through, the unused far end of the threaded hole will be fairly corroded so back out may be best. There are things called 'easy outs' (although its never easy!) which are like reverse threaded and tapered bolts or screws. Drill a pilot hole as centrally as possible, then get the easy out in the hole and tuen it anticlockwise - it should grip and extract the bolt.
    If you try to drill it out you have to be very precise and not damage the socket - not easy if the hub material is softer than the bolt itself.
    Editted to add,
    Example here: http://www.axminster.co.uk/product-A...Set-462398.htm
    Use a centre punch to mark the centre before drilling and use the right size for the bolt.
    May 2008
    Tyneside
    If you take the wheel off there may be enough of the stud showing to get some grips on. Otherwise you will have to drill a hole in the stud and use a stud extractor. The tightening torgue for roadwheel bolts is 80lbf ft (110Nm) though most people overtighten them for fear of the wheel coming off.
    Jul 2006
    Northampton
    Trim : Sri
    Cheers guys, i may have to try this then
  1. Snapped tensioner bolt, help :(
    By danny2009 in forum Engine & Drivetrain
    Last Post: 29th April 2013, 17:14
  2. Oops!! Snapped the seatbelt bolt!
    By SlowCoach in forum Bodywork & Interior
    Last Post: 24th October 2012, 11:49
  3. Snapped a bolt ,,,,hahaha
    By collyb in forum Engine & Drivetrain
    Last Post: 6th June 2011, 23:53
  4. bolt snapped
    By tappetpaul in forum Engine & Drivetrain
    Last Post: 14th March 2011, 23:43
  5. Snapped Wheel Bolt
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 10:17
