Results 1 to 10 of 19
Thread: number plate lights ?
    ireland
    Default number plate lights ?
    how does one change the bulb for number plate lights in vec c ? Advice appreciated
    Blantyre
    Look above the number plate and you will see the lights, to each side there is a small flap, get a small screw driver and push them to one side and they should pop out, and change the bulb from there
    ireland
    Thanks. Wanted to be sure in case I broke anything.
    Blantyre
    When you take it out, if i remember the bulb holder twists out
    ireland
    Thanks again. I nearly forced out the holder with the screw driver!!!!!
    Mileage : 000
    Must be different on the estate. I pulled the light fitting out with my finger nail, then the bulb just pulls out, it is a capless type.
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    ^^ long finger nails;P
    Jan 2010
    Glasgow
    hey guys.. was changing the number plate bulbs today and ended up braking the little flap with the screwdriver that holds the bulbs into place! where can i buy that light bulb holder? cant seem to find that part on ebay
    Aug 2009
    sheffield
    hi, put vectra breaking in as search. loads of vectra c models breaking. email/ring the yard you fancy.
    11 Post(s)
    Quote Originally Posted by vectra57 View Post
    Superglue?
    Else try Vauxhall themselves.
  1. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  2. number plate lights
    By veccy c in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 15:50
  3. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  4. number plate lights
    By Robbie69 in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2009, 22:19
  5. Number Plate Lights
    By Stringlabel in forum Vectra C / Signum Troubleshooting
    Last Post: 24th December 2005, 13:17
