Results 1 to 10 of 13
Thread: Springs
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default Springs
    Can anyone confirm which way up rear springs go, is it the more tightly wound coils at the top or bottom? thanks for any help.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    top
    Oct 2007
    Ellesmere Port
    thanks
    Oct 2007
    Ellesmere Port
    the springs are like this /// / / / / so the close ones go at the top?
    Oct 2007
    Ellesmere Port
    bump
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    i have 2 sets of motorcycle shox and on both the tightly wound coils are at the bottom,yes i know it is not a car but the way the spring works would be the same,in fact im almost certain they need the close coils at the bottom to work properly
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    but this pic which is the front suspension shows the tight coils at the top http://www.modyourcar.com.au/images/..._type_co_1.jpg
    Regular Member teera2uk's Avatar
    Oct 2007
    Lincs
    tighter coils to the top something to do with the weight not being so much on the axle which i suppose is true
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    having a look at various sites the fronts do tend to be tightly wound at the top,the rear can be either depending on where the driven wheels are,if you have a look at the spring is there any writing on it? this should tell you which way to fit the spring as you install it with the writing the right way up
    Oct 2007
    Ellesmere Port
    I've done it now, I put the tighter ones at the top. It looks a bit high but will prob settle after a while. Its on an Omega I have just bought for towing with. Thanks for all the replys. Dave
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
