Results 1 to 10 of 11
Thread: broken front springs
    Regular Member 30ltr nutter's Avatar
    dunstable
    Default broken front springs
    hi guys just checked car over today found broken front n/s spring and cracked o/s front spring does any one know what lowering srings i can fit to a 30cdti sri iam thinking about changing the fronts and rears so to keep it right but i dont realy want to change the struts unless i have to the car is a preface lift 2005 estate
    Cambridgeshire
    You can get Eibach Pros (30mm) lowering all round. However because yours is an SRI it is already lowered 15mm than standard Veccy's so it will lower it by 15mm. You can get them for any model
    HTH's
    dunstable
    many thanks parsco do lmf do the springs or where can i get them and do u know an approximate cost
    Regular Member ssmotoboyz's Avatar
    wednesbury
    Default lowering springs
    check your front axle rating as i think only KW supply the correct ones for the 3.0ltr,i have these on mine with bilsteins
    Cambridgeshire
    Quote Originally Posted by ssmotoboyz View Post
    That is another option
    Yep, LMF sell them and you are looking at about £160 ish plus delivery (all round). However, as ssmotoboyz said check your axle weights first and make sure that LMF do them
    dunstable
    cheers guys stripped out fronts today both springs broken at the bottom on last coil looks like they have been broken some time will call lmf tomorrow to see what they can do for me many thanks for your help will post pics when done
    Staffordshire
    Pardon my ignorance - I am sure the acronym has long since become common usage and everyone knows who they are apart from me - but who are LMF?
    Please post a web address!
    dunstable
    hi www.lmfvauxhall.co.uk try the site i used them for the springs very helpfull indeed
    dunstable
    just an update spax sports springs 30mm arrived friday fitted fronts and rears today i will let them settle then post pics
    Quote Originally Posted by 30ltr nutter View Post
    Glad it sorted m8 ........
  1. More broken springs
    By marktaylor in forum General Motoring Chat
    Last Post: 16th March 2012, 22:12
  2. Standard SRI springs. One front one broken
    By connery-sri in forum Parts for sale
    Last Post: 9th September 2010, 06:59
  3. Two broken front springs
    By ed taylor in forum Suspension, Wheels & Brakes
    Last Post: 31st December 2009, 11:36
  4. Broken Springs
    By SilverLighteningGSI in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2008, 10:04
  5. broken front springs!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2007, 00:46
