Thread: Noise from rear - strange remedy
    Oslo
    Default Noise from rear - strange remedy
    Hi all
    I have just bought a 06 vectra c estate 1.8. And I have enjoyed reading about future problems on this forum for a while .
    The thing is that I have a annoying noise coming from the rear when hitting bumps etc. The sound is best described as a bouncing parcelshelf something of that kind. Ive owned bothe a vec a and B previously, so Im kind of familiar with troubleshooting strange sounds
    I have read all the post on the subject, but here is the strange thing: It disappears when i wash the car.. I know it sounds like a bad joke, but its not. The first time I thought it was a coincidence, but its not. After i have hosed the car in one of those DIY washing places the car is perfectly silent. I really started to dubt my judgement (and hearing). Does anybody with developed logical sence point me in the right direction on what to look for ? I have checked the boot for any loose objects that theoretically could have been "pushed" into place by the waterjet, but no luck. Sorry for the long post, but this noise is driving me nuts.
    any advice appreciated
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    I had a noise coming from the back which took me ages to figure out!! Turned out to be a loose radio aerial, a quick half a turn and noise gone!!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Maybe the water is lubing something when you wash it and stopping the noise, have you tried treating your aperture seal with some Vinyl and Rubber Care? Or even Vaseline?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Water must have got to some of the bushes on the rear (antiroll bar, is there one on the rear, I don't know)
    Mileage : 55000
    I was thinking the same the water is acting as a lubricant. Next time you wash it look to see where the water has "splashed". it might indicate where the knocking is coming from. Thing is I would have thought a knock would still be there even when the offending part had been lubricated. A squeak I can understand that disapearing though.
    Oslo
    Thanks for all the replies.. I see the "lubricant theory", but that would imply that the same effect would be achieved under wet/damp conditions ?And that makes no difference.. however, Today I hosed only the back of the car not touching anything underneath or the wheelarches to try to eliminate the bushes. Just a quick hosedown from the rear (the gasstation people probably thought something was wrong with me The noise disappeard as before. Obviously its something with the rear hatch, but I have checked all parts (not that there really are many possible parts that could be influenced by water under pressure as far as I can understand)..?) and I can not see anything that is loose. I even removed the rear licensplate to be sure.. BigP: This apperture seal you mention - where is it actually located ?. Im afraid thats one word I missed in my elementary school english class- sry. for the ignorence.. Greetings from Snowy Norway
    Regular Member wiggy's Avatar
    middlesbrough
    just keep the car clean hahaha
    Staffs
    Hi
    I have just fixed a similar prob on my 52 plate 2.2 SRI, I had a thud when going over rough roads which could of been described as the parcel shelf thudding. After changing all the recommended shocks springs anti roll bar bushes I found that the fuel tank shield was slapping the underbelly of the tank. I put some packing between the tank and shield and the noise has gone away, happy days.
    regards
    Tony
    Regular Member aps's Avatar
    cheshire
    Vehicle : Vectra C Sri CDti 150 (satnav)
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Hmmmmm.. ive been watching this with great interest .. i have the very same noise !
    On a previous car i actually traced it to the parcel shelf so added pads to stop the jumping etc ! thats exactly what this sounds like as mentioned but ..... looking above i suspect its way more than that .
    Ill try a couple of things as said above ... keep you posted
    cheers
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I have the exact same problem if might take alook at the heat shield
  1. strange noise from rear drivers side
    By chris_20 in forum Engine & Drivetrain
    Last Post: 27th February 2010, 21:47
  2. Strange grinding noise coming from rear wheel
    By sproket in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 22:04
  3. Strange Noise from Signum Rear End
    By powelly1592 in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2009, 01:34
  4. Strange noise - rear near side
    By dave200 in forum Suspension, Wheels & Brakes
    Last Post: 2nd July 2008, 14:12
  5. strange noise from rear????
    By dave16v in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2008, 22:21
