Results 1 to 10 of 23
Thread: Wheel balancing
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Wheel balancing
    How many members hear have had wheel wobble issues after
    having new tyres fitted ? or how many times have you gone back
    to the dealers to sort it out ! im on my third now, and im getting
    a bit peeved !
    Regular Member Robbie69's Avatar
    had the same mate,
    Robbie
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    When I bought my SRi the steering wheel wobbled a bit when I was driving so took it to the stealers and they balanced the wheels AND adjusted the tracking, so it may not be just the balancing that needs looking at.
    Chester
    Just once. Somebody then recommended a place locally they knew what they were doing and they have all been perfect since. No Vibration at all.
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    not often, but did have issue once when i brought some cheap alloys for my old Cavalier SRi, never sat right on the hub, causing this, other time garage reckoned that i had a dodgy wheel, had front two done at ATS/KWIKFIT etc.. everytime perfect, took it to a local, Collins tyres in portsmouth, balanced on the car.. all four! SORTED. back two needed doing causing the wobble... worth try a local firm there more helpful i find.
    Regular Member hyperman's Avatar
    pontefract
    it all depends on how the wheels are balanced, are they alloys or steel wheels?
    Feb 2007
    Tamworth
    Quote Originally Posted by hyperman View Post
    19" snowflakes with new conti's !
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    I find any steering vibration even just a tiny amount unaceptable... really spoils the pleasure of the driving experience.
    I had to have mine balanced twice after the last 2 new front tyres were fitted on my vec-c. After the first balance I waited about 1k miles before I had them done again, to give the tyres time to settle in, even new tyres are never 100% round according to the manufacturer's. After balancing the second time they were spot on at all speeds. Steering has been as solid as a rock since.
    One thing I have noticed is that not all tyre fitters seem to know how to a fit a tyre properly, ie. to fit the tyre so the coloured spot which is the lightest point on the tyre is lined up with the valve, often resulting in larger weights than need to be fitted had it been lined up properly.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    yeah, i had this problem. steering was shaking like crazy - at times.
    most of the time it was alright, but when it started it'd carry on for miles.
    had them re-balanced, and the problem disappeared.
    seems like the vectra steering is very sensitive to wheel balancing issues.
    never noticed it so much on other cars.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by Kcs View Post
    same here, mine vibe at 60-75mph it really gets me down
  1. Wheel balancing
    By Ziggy in forum Handling & Braking
    Last Post: 23rd July 2012, 14:32
  2. Wheel balancing
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 23:03
  3. Tracking/Wheel Balancing
    By David_SRi_2.2DTi in forum Suspension, Wheels & Brakes
    Last Post: 13th August 2007, 16:29
  4. Wheel Balancing again !!
    By PIMM in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2007, 22:17
  5. Wheel Balancing
    By Manni2375 in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2006, 01:26
