Thread: CDR2005 Upgrade
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    Default CDR2005 Upgrade
    Is it just simple as plug and play for standard HU's? can i put a CD30 or somthing like that in to mine or do i have to get it Tech2'd?
    or is it easier and cheaper in the long run just to get a aftermarket one?
    Ta, Will
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by redraptor_141 View Post
    no, a CDxx is as good as impossible; only a CCR2006 would be easy
    yes
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    go for an after market one m8 as you can run in to all kinds of problems, is your car half can-bus? (buttons on the sttering wheel or roller balls?)
    dont have any buttons at all annoying really dont know what that means though
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    2004 should be half canbus, you can get a vx headunit fitted but it has to be tech2'd out of the donor car then again tech2'd into your's......i have a full canbus car and have fitted a sony head unit with the sony interface so i can still use the wheel remotes and still have the centre screen useage.....
    hth
    Midlands Mod Shop - NFFC.
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. Want To Upgrade My CDR2005 - What Will Work?
    By AdeV6 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2012, 20:04
  3. CDR2005 Upgrade.....
    By Whisky in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2011, 14:52
  4. Cdr2005
    By glenboy in forum Parts for sale
    Last Post: 22nd August 2009, 20:11
  5. Cdr2005
    By Gaffy in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2009, 00:39
