Results 1 to 10 of 22
Thread: More Power Required!!!
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Default More Power Required!!!
    How can I get more boot out of my 1.8 petrol Sri? TBH it is not that much more powerful than my 1.8 LS I had before! It looks very nice indeed but needs to back up the awesome looks with a bit pace!
    Plymouth
    im 99% sure that the sri will have the same power as the LS.... the specs have nothing to do with the engine... i think...
    Regular Member darko2301's Avatar
    Croatia
    it really isn't related in any way mate...
    Regular Member adamtaylor's Avatar
    Witney (OXfordshire)
    unless its a vvti engine in the new one then he would have the extra 20hp or whatever the figures are over the ls!
    Aug 2007
    Cupar, Fife
    its a VVTi engine in the new one and it is quicker but not that much. From a standind start it will rape the LS but through the higher engine range its about par.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    1.8 sri should have a closer ratio gear box - stiffer suspension and sport's seat's over the LS other than the obvious body differences......
    as for more power the cheap way to go would be air box mod & high flow air filter so it is getting more air in and a larger bore sport's exhaust so it get's rid of the bad stuff quicker...cam's apgrade and a remap and this should give you about 30% more bhp over the average..
    the more expensive way is to have a turbo and all new internals fitted...mega money and good gains but if you dont get stronger internal's then they will go pop with the addition of the turbo.....
    Midlands Mod Shop - NFFC.
    Aug 2007
    Cupar, Fife
    Cheers mate, I did the airbox mod on my LS but it sent the emmissions through the roof and subsequently failed the MOT!, Vx said the restrictor in the air box is there for a reason and should not be removed and this was the reason my car failed the emmission part of the MOT due to overfuelling (more air in, more fuel pumped in by ECU and higher CO output)
    Trim : Get a
    Quote Originally Posted by KSD View Post
    never heard of that before mate...
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Quote Originally Posted by ditchp View Post
    Me neither? i done mine a week before my MOT and flew through...think their could have been another issue other than that...
    The airbox mod is a MUST IMO...my ls was dead on take off...also the shorter gsi/vxr intake pipe
    Aug 2007
    Cupar, Fife
    There was nothing else it could have been, both O2 sensors were checked and the CAT got a once over, as well as the EGR valve, then I put the restrictor back in and it passed!!! I would love it to be something else as the airbox mod gave a bit more kick but I am reluctant to do it again on the SRi.
  1. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th June 2011, 11:30
  2. help required(lost power)
    By bbb69 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 19:00
  3. Your views required or help required??
    By Colin S in forum Detailing and Car Care Discussion
    Last Post: 18th September 2008, 02:15
  4. More power required!
    By signumkev in forum Diesel Engine related
    Last Post: 20th January 2008, 11:31
