Thread: Parrot SOT Leads
    West Midlands
    Default Parrot SOT Leads
    I am currently using a Parrot CK3100 Bluetooth carkit with my CD30. I was thinking of upgrading to one of the newer MK range but just wondered if anyone knows if the existing SOT lead will work with the newer Bluetooth Kit?
    Chris
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    Default car kit
    go for the new bury 9060 car kit had them fitted to both cars today and they are the nuts
    WGAF#5
    should work with all parrot kits your existing wiring will proably be ok from the parrot kit as well if your really lucky
    i'vr got a mki9000 and the sound quality is great
    comes with ipod connector, usb connector and 3.5mm jack
    as well as streaming bluetooth stereo - multi purpose covers all bases
    West Midlands
    Also have a Denison FM Kit fitted with the direct connecion to the CD30 HU. Anyone know if the quality through the Parrot MK Kit 3.5 Aux / ipod connector socket would be better? I'm assuming the connection is more direct than the FM signal that the denison kit creates?
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Quote Originally Posted by MrS View Post
    Mki would have better qaulity for certain and yes your existing SOT lead will work fine. Mki kits are very good, still a little buggy but getting better with every update (easy to update via USB memory stick as well)
    Bury kit is fantastic and better as a car kit however not a patch on the Parrot for music etc
    WGAF#5
    Quote Originally Posted by Maddog1974 View Post
    latest update was friday now running version 1.11 on all mki range
    3.5mm socket sound is very clear! cheapest option i found was to down load all songs to usb memory stick and just leave it plugged in
    dont have to worry about leaving ipod in the motor then!
  1. Jump Leads ...
    By macdad in forum General Chat
    Last Post: 6th December 2010, 23:03
  2. i need some leads
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2010, 22:24
  3. Pre Out Leads For Cd70
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2008, 21:37
  4. Replies: 31
    Last Post: 31st July 2008, 18:17
  5. What leads..
    By Pinman in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2006, 21:47
