Results 1 to 10 of 17
Thread: 3.2 v6 GSI.. what can i do to it
    asdasd
    Default 3.2 v6 GSI.. what can i do to it
    Ok Vectras been in the garage for over 2 weeks getting a new engine rebuild...(over 2grand spent, very slow, waited for parts from all over the place)..
    Anyway what could i do to get the best out of my engine performance wise and fuel wise..Anything would help. Thanks
    Mileage : 000
    Without spending a fortune on it not a lot really.
    asdasd
    Iv heard of buying a k and n air filter...would that help in anyway and what does that do?.
    Mileage : 000
    It will help a little. But just the Air box mod is an improvement. A K+N Filter will allow more air into the engine. As it is less restricted.
    Regular Member pjjohnst's Avatar
    Shetland Isles
    - I did the airbox mod, and installed a K&N panel filter and found the car to be more responsive & smoother through the rev range
    Last edited by pjjohnst; 6th March 2009 at 19:10. Reason: mispelt some words - doh !!
    norn iron
    heard removing the cat has good results on the 3.2
    Shetland Isles
    Quote Originally Posted by deg View Post
    Thats my next plan when finances prevail - a new exhaust system with decat
    Regular Member Harro's Avatar
    Jan 2008
    York
    Quote Originally Posted by Hasaam View Post
    What happened to your engine?
    asdasd
    erm basically brought it drove it around for a week...(got it cheap so even tho i spent 2 grand on it it still cheap)...but yeh...started it up one morning massive amounts of blue smoke was coming out and engine was loud..rattling...shaking....when i would stop at the lights the whole car would shake as if it was trying to stallll, but wouldnt stall...even in neutral...but yeh took it in...they said it could be anytthing and wnt knw until theyve opend the engine...sooo yeh from there...headgasket, piston rings, sum gasket?, cambelt, catalytic convertors. and everything else is being cleaned...So far hes stripped the engine, and waiting for parts..will continue work on monday/tuesday once all parts are recieved.
    Regular Member hagga's Avatar
    kingswinford
    it depends on what sort of power you want, a bit more or lots more? if the latter, whilst the engine is out and stripped there are endless things you can do (increase bore size,change comp ratio,lighten and balance crank,cams and headwork etc) but this depends on your budget.. If you just want to improve on what you have, air filter,performance exhaust,decat and remap is the way to go
