Thread: egr and inlet manifold
    May 2008
    Wiltshire
    Default egr and inlet manifold
    vectra elite 1.9 deisel 150 estate 04 plate
    just got the car from the garage, due to car+spanner and emissions lights on.
    mechanic said egr at fault, took apart sure enough clogged solid. he gave it a clean to the car for a test drive and the lights are back
    mechanic said give it a week to see if lights go away if not new egr required. (its ok warranty will pay for broke parts but not for cleaning and adjustment)
    would it be worth cleaning the inlet manifold? he said that these can get really clogged up? anyone done it? how difficult?
    cheers
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Before you fork out for new egr valves have a look at the existing thread.s on checking vacuum hoses and turbo feed pipes also clean your boost sensor housed in the inlet manifold all these cleaned and checked properly will make a world of difference.
    and still loving it
    Regular Member ptrehearn152's Avatar
    norfolk
    Default inlet manifold
    hi just done mine, not too bad a job, need to remove water hoses from egr and injector pipes and bleed fuel system after cleaning but not too difficult if you take your time, longest part is cleaning everything up.
    Regular Member phykell's Avatar
    Apr 2008
    Cheshire
    I bet the mechanic didn't drill the solenoid housing to remove the parts for cleaning. In my very recent experience, there's little point in cleaning the valve and intake unless you also take the solenoid apart and remove any corrosion, applying copper grease before you reassemble it.
    I tried cleaning my EGR and having replaced it, it seemed to improve a slight bit but the problem reoccurred very quickly and the engine management light came on a few times. Sorting the solenoid and cleaning the MAF sensor has resulted in a transformation - the car pulls from low down, and does so better than I've known it to do since I bought the car last year.
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Default EGR Solenoid side cleaning
    This should resolve your problem.
    I just found another great How 2 on cleaning the solenoid side of the EGR valve which is next on my list of things to do. Just wanted to share it with you.
    http://www.vectra-c.com/forum/showthread.php?t=45867
    And a handy little printable PDF too!
    http://www.vectra-c.com/forum/attach...7&d=1232829228
    Thanks in advance to "Jon7278" for putting the How 2 together and
    "cdti 150 SRi54 est" for the PDF.
    If it's under warranty you might as well get a new EGR valve I have read on here somewhere that there is a modified EGV valve replacement part and a new set of gaskets that block off the EGR to the manifold slightly. Ask when they fit it to check to make sure you get the most recent parts.
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
