Thread: Plasticy rattle from nsr...
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Plasticy rattle from nsr...
    any ideas would be good, its been going on for over a month now, it sounds like a some sort of trim rattle, it sounds like it coming from the nsr corner but it doesnt make the noise all the time just now and again.
    has anybody else had this? if so what cured it?
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    is it not the parcel shelf?
    mine does this at it does my head in - had to put some foam type stuff on it to try and cushion it a bit
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by monkeez View Post
    it still does it with the shelf took out
    Regular Member mark_w's Avatar
    cheshire
    have you got any sunglasses in the roof console? mine rattle in there sometimes.
    Sunny Dartmoor
    How about something fallen down between the side of your motor and the trim in the boot?????
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by mark_w View Post
    no mate,no sunglasses in the roof console
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Are you sure it's inside? I had a rattle I was convinced was inside the car and it turned out the exhaust heat shield had corroded through the bolts and was rattling on the exhaust.
    Worth a check underneath and see if you can check they are secured - check both the centre and back box one(s).
    Regular Member old cruiser's Avatar
    slough
    Check the roof lining at the back, often comes out of the rubber hatch seal.
    Cheers Pete
    Northampton, UK
    My centre arm rest/storage thing rattles like crazy... Just wish I could rip it out sometimes, its such a flimsy pointless lump of cheap plastic.
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Could be the plastic trim on inner side of the
    hatch, the one below the glass with the grab
    handle on, rattles on the contact point between
    the trim and the glass ! or the hatch locking
    clasp, rubber screws need adjusting out a bit
    ( maybe ! )
  1. DMF rattle
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2013, 13:31
  2. Bad rattle!
    By heheshamon in forum Bodywork & Interior
    Last Post: 16th April 2010, 20:37
  3. rattle rattle
    By jaytops2k1 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th September 2009, 19:07
  4. A rattle at 70
    By Jezza181 in forum Engine & Drivetrain
    Last Post: 25th March 2009, 08:02
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
