Results 1 to 10 of 14
Thread: ERG Cleaner, confusion??
    North East
    Default ERG Cleaner, confusion??
    I read somewhere that people use carb cleaner on their ERG valve. Having looked at the Wynns carburettor cleaner can it states on the instructions for petrol engines.
    Can this be used on the ERG valve of a diesel engine (if the ERG valve is removed) to clean it?
    Sorry for the numpty question
    Michael
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    In a word yes M8 any carb cleaner is good enough but as it happens wynn,s is what i used on mine last week
    North East
    Thanks for clearing that one up!
    Do I just need to spray it on, leave it a while and wipe of or does it take some scrubbing to clean it up?
    Regular Member Bethan39's Avatar
    South Wales
    I believe most people leave it to soak for a while
    Engine : 2.0DTi
    Mileage : 73350
    you can soak or just blast it out with the carb cleaner it is easier to see than explain ,just split the ergin half and all becomes clear or gunged up! as is usually the case.
    Glasgow
    EGR = Exhaust Gas Re-circulation valve
    Regular Member Preey's Avatar
    May 2008
    Hudd
    I did my lads the other day and soaked it in petrol it did the job
    Edinburgh
    I think some folk use a tooth brush to clean it with the carb cleaner.
    Regular Member videodoctor's Avatar
    Blackpool
    Quote Originally Posted by knoxvillain View Post
    use a tooth brush to clean it with.
    Then put it back for the other half to use later
    North East
    Well I sorted it out this afternoon. I used a new product from wynns. Its a aerosol can that you spray the entire contents down the air intake. this cleans the pipes and the EGR valve. I have tested the car this afternoon and so far it's 100% better. I didn't even need to remove the EGR valve. Will see how it goes over the next few days and hopefully that will be it.
    Happy Days.
    Thanks for your help.
  1. DPF confusion.
    By JayF in forum Engine & Drivetrain
    Last Post: 7th April 2012, 10:00
  2. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  3. TID & GID confusion
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 18:28
  4. Replies: 7
    Last Post: 2nd July 2009, 17:51
  5. HID confusion
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 15:08
