Thread: Spanner Light, No Code, Poor MPG - WHY?
    Leicestershire
    Default Spanner Light, No Code, Poor MPG - WHY?
    As my title states I am getting a spanner light appearing and when I try and read the code via a U581 there isnt one. I reset it and after one run its back. WHAT IS IT??
    The car seems to run ok but I have poorer MPG and maybe have lost a bit of umph!
    Please help
    Blantyre
    You checked your pipes mate, i dont have a diesel but i see alot of threads on this
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi mate as spenny said check your vacuum hoses around the connectors for split,s
    very common fault .also check your turbo feed hoses for splits , just get some one to rev your engine while you listen under bonnet .
    Leicestershire
    Thanks for the tips on checking my pipes....
    As a complete novice who hasnt touched cars for years is there an idiots guide/photo anywhere around showing me which pipes to check.
    I know this is a stupid question but it will save me lots of head stratching!
    Thanks,
    Mark
    Leicestershire
    Smile
    Well hopefully sorted it!!
    As it was light last night when I got home from work and decided to lift the bonnet and have a look......
    starting at the airbox....Mmmm hose disconnected, it was the one on the front of the air box that connects to the radiator, it was completely off on the airbox side.
    I have now pushed it back on and reset the EML and all seems good on the drive to work and no reappearance of the EML light
    My question is - is that pipe really only a push fit connection on both ends???
    Mark
    Leicestershire
    confused
    Mmmm not sorted it!
    At the weekend I cable tied the hose at the front of the air box on and I did the airbox mod by removing the plastic bit. I then reset the EML spanner light and all sorted - WRONG!
    Around 100 miles later the spanner light came on.
    I am beginning to think this hose is a red herring - I have looked and all the hose seem ok and now the car runs fine - mpg might still be low though.
    Any ideas now - I just hate having a spanner light and no error code on my U581 reader - where can I get an error code????
    Please help this very frustrated Veccy owner
  1. spanner light but no error code
    By danno91 in forum Engine & Drivetrain
    Last Post: 12th October 2011, 19:20
  2. Spanner light, but no code.
    By hothatch in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 22:55
  3. spanner light with no code again
    By iasha in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 16:41
  4. spanner light with no code again
    Last Post: 1st July 2011, 06:55
  5. spanner light on poor starting?
    By conny in forum Engine & Drivetrain
    Last Post: 31st May 2011, 18:53
