Thread: Headlamp beam adjustment for europe
    Fife
    Default Headlamp beam adjustment for europe
    Am taking the car and caravan over to france this year,
    Its a legal requirement to have the headlamp beams reconfigured for euro roads.
    Does any one have any info on how to do this APART from fitted stick beam adjusters?
    Many thanks
    DAVE
    Regular Member Robward27's Avatar
    Witham
    There are levers on the back of the headlights someone on here will tell you more info.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, it is a legal requirement.
    My pre facelift, normal headlight car has levers under the rear headlight assembly cover. Little plastic white levers that adjust the beam pattern. Work well, and easy to do, and no mess from stickers.
    Look here, http://www.vectra-c.com/forum/showth...t=lever&page=2
    Fife
    Many thanks.
    Think am just going for the suck it and see approach. lol
    Regular Member madman's Avatar
    nottm
    on my 04 elegance. you need an allen key to turn a screw behind the headlight unit. not sure which way to turn tho. although i'll have to find out before invading europe.
    madman
    2.0dti elegance estate. bog standard
    Regular Member dave45040's Avatar
    llandudno
    Goonturbo,
    I note from your profile you have a facelift Vectra. On the assumption that the lighting is the same on this as it was on my facelift Siggy, I was informed that there is NO adjustment for the headlights - and therefore I had to buy the beam deflectors when I went over to Spain the last couple of times.
    I know there have been a number of threads about this previously so have a good look at old posts - you may find you have to just use the stick on ones after all!
    Dave
  1. main beam adjustment
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 16:09
  2. RHD to LHD headlamp adjustment
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2010, 09:55
  3. Dipped beam adjustment
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 07:06
  4. Main Beam Adjustment
    By hefilump in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2009, 23:05
  5. Lighting Beam in Europe
    By carlton in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2006, 23:41
saab 93 06 headlight adjustment for europe
how to adjust vectra c headlights www.vectra-c.com
adjusting headlights for spain on a saab 93
